TypeError:sbPartList[j] has no properties
Thread begun 3/17/2013 2:37 pm by Daryl | Last modified 3/20/2013 7:57 am by Jason Byrnes | 3607 views | 5 replies |
DarylBeta Tester
I have today been getting a bizare error message when trying to add a static plugin to a page.
The message "TypeError:sbPartList[j] has no properties" appears after choosing the plugin and pressing OK.
It only does it on this one page though..
The page is attached
at the end of line 63, i see the following code repeated:
<?php echo((isset($WA_menu_1363554657148))?$WA_menu_1363554657148->Head:""?><?php echo((isset($WA_menu_1363554674539))?$WA_menu_1363554674539->Head:""?><?php echo((isset($WA_menu_1363554721135))?$WA_menu_1363554721135->Head:""?><?php echo((isset($WA_menu_1363554839250))?$WA_menu_1363554839250->Head:""?>
but i dont see the menu plugin in the list of plugins or in the other parts of the page.
try deleting that code then adding the new plugin again.
DarylBeta Tester
Hi Jason
I have tried that, but the same thing has happened...
the title tag:
<title><?php echo $row_Recordset1['blog_title']; ?></title>
uses a recordset variable, but there is no recordset on your page.
DarylBeta Tester
Unfortunately that didnt help either.
I ended up building the page from scratch again and its now working.
Ok, glad to hear rebuilding the page fixed the problem.
