Mailing Audience
Thread begun 3/14/2013 1:41 pm by QuiruNet | Last modified 4/09/2013 9:08 am by Jason Byrnes | 3069 views | 7 replies |
QuiruNet
Mailing Audience
when i try to put the audience in the newsletter, the progran don't save the information. Doesnt't work...don's save the changes..
now i hat this mesage:
Warning: mysql_pconnect() [function.mysql-pconnect]: User kikeaventuras already has more than 'max_user_connections' active connections in C:\inetpub\vhosts\aventurasengalicia.com\httpdocs\mailing\Connections\PowerMailerConnection.php on line 14
Fatal error: User kikeaventuras already has more than 'max_user_connections' active connections in C:\inetpub\vhosts\aventurasengalicia.com\httpdocs\mailing\Connections\PowerMailerConnection.php on line 14
in the Connections\PowerMailerConnection.php change the following code:
$PowerMailerConnection = mysql_pconnect($hostname_PowerMailerConnection, $username_PowerMailerConnection, $password_PowerMailerConnection) or trigger_error(mysql_error(),E_USER_ERROR);
$PowerMailerConnection = mysql_connect($hostname_PowerMailerConnection, $username_PowerMailerConnection, $password_PowerMailerConnection) or trigger_error(mysql_error(),E_USER_ERROR);
it may take a little for the existing connection to time out, so it may not take efect for a few hors or more.
QuiruNet
its the same code
it still, not working, i can save the changes i make in audience...to send the newslletter..
I replied to your message only 30 minutes ago, see the note at the end of my original replay:
QuiruNet
mailing Audience
i try later, but i happen again, i am trying two get the audience and it doesn let me safe the changes...in the query and also in the groups and etc.....i can use the powermessenger...
I will need to see the probem in order to troubleshoot the cause
