Redirect
Thread begun 3/14/2013 7:24 am by tkendrickmail32213 | Last modified 3/14/2013 1:40 pm by Jason Byrnes | 3041 views | 7 replies |
tkendrickmail32213
Redirect
I don't see a function allowing us to send the user to a confirmation page when submitting the form. Does this not exist? I need it to perform like this.
the redirect is done in the server behaviors that process the form information.
for example, if you are storing the information in the database using the insert record behavior, you set the redirect in the insert record behavior so that after the record is inserted, the page is redirected.
tkendrickmail32213
where?
what button does this? Edit form or Edit contents? I need step by step please?
Also, where do I changed the form fields?
it is not done in the form builder wizard, it is done in whatever server behavior you are using to process the form.
You change form fields by editing the form.
tkendrickmail32213
error (for hours)
I have repeatedly tried to add an address to whom this form can go to. I get a syntax error on line 22 every time in dreamweaver. this is a bug. I have wasted hours on this issue!!! What do I do to fix this?
here is the Url with the error: form-shower-pan-measure-beta.php
tkendrickmail32213
what server behavior
What button to execute the server behavior. I want it to redirect to another page when they submit it.
When I press "Edit Form" where do I go next? Your documentation doesn't describe this.
tkendrickmail32213
additional notes
Why does it send "Additional notes"? How do I turn this off?
What is the error?
I cant see you page, it requires a password
can you send the text of the error and a copy of the page.
