Reenter form gives me <new from blank> Default
Thread begun 3/13/2013 11:51 am by mick106153 | Last modified 3/13/2013 12:40 pm by Jason Byrnes | 1767 views | 3 replies |
mick106153
Just installed DataBridge after cleaning out all the old stuff. Using css form builder I made a custom form and didn't save it as a unique entity. In the past I could reenter the form no problem. Now when i reenter, my form is nowhere to be seen.
The only thing I did outside the form builder was to impose an id on a single element within the form for structural purposes.
Is this the way it is now or did I break it by making changes outside form builder?
A work in progress - always changing here
imagecontest.php
Mick
to reenter the form builder wizard, click a for element in design view, then select the form tag in the tag selector along the bottom, in the properties window, it should show an edit button to allow you to edit the form.
mick106153
Doesn't work. cannot access the from here imagecontest.php
Created a new form here imagecontest%20-%20Copy.php and named it and i can access it.
