File Upload / Download help
Thread begun 3/13/2013 5:57 am by iainmacdonald331081 | Last modified 3/14/2013 1:37 pm by Jason Byrnes | 5940 views | 10 replies |
iainmacdonald331081
I have had no problem uploading images, but am having trouble getting mp3 files to upload.
In testing it works with JPGs etc, but wondering if I need to specify other file types allowed somewhere before it will upload mp3? I've ruled out any file size limit issues.
Also having trouble with my file download button - all I've managed to get it to do is download the .php page, so hopefully something simple if it is downloading something. I've checked the folder and the contents in the folder.
One thing though - when I try to create the trigger, I don't see Button:download pressed as an option, so have been using Any Form Post.
Have attached copies of each page.
Thank you.
You don't have the Web Images only option selected. So it is probably the file size of the MP3 that is causing the upload to fail.
There are a number of PHP Settings that can effect the maximum file size you will be able to upload.
see this page for details:
wap_upload.asp?page=php2
for the download problem:
1) Remove the form that is around the repeat region, and add a form around the download button
2) change the download button element from type="button"
<input type="button" id="download" value="Download" name="Download" />
to type="submit:
<input type="submit" id="download" value="Download" name="Download" />
3) Add a hidden element next to the download button and bind it's value to the file name column from the recordset.
4) In the download behavior, bind the file settings to the hidden element.
iainmacdonald331081
Thanks Jason. I did initially get an error on the server:
413 - Request Entity too large
So I requested the host to increase the limit. They advised me that they'd increased the limit to 10MB (the sample files I have are around 3MB).
I've gone back to the hosts to double check they've changed any settings at their end. (I don't have access to the php.ini file)
Will have a look at the download stuff.
the are probably only changing the upload_max_filesize setting.
the post_max_size size will probably also need to be inscreased, and depending on the network connection, you may also need to increase the max_input_time and the max_execution_time
iainmacdonald331081
I've deleted the opening and closing form tags, and have this around my download button:
<form class="DetailsPage Basic_Default" id="Results_Basic_Default"name="Results_Basic_Default" method="post" action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>">
<input type="hidden" value="" />
</form>
How am I binding its value again?
Was looking in the properties for a lightning bolt?
if your using DW CS6, adobe have removed dynamic bindings from form elements.
using code view, open the bindings panel and select the file name column from the recordset, then drag it to the code and drop it between the quotes for the value.
iainmacdonald331081
Thanks Jason - I did wonder.
The hosts have made the other changes, so the upload is all fine now too.
iainmacdonald331081
Think I'm still not quite sure - am I associating the hidden field and / or the file in the download behaviour as the field in the table that stores the file name, or the file itself?
Have attached a revised version that I haven't got right.
for the hidden element, expand the WADAMusic recordset, and use the file name column for it's value.
iainmacdonald331081
Sorry Jason - still not getting it to work.
I have my form as:
<form id="form1_" name="form1" method="post" action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>">
<input type="submit" id="Download" value="Download" name="Download"/>
<input type="hidden" value="<?php echo($row_WADAMusic['Music']); ?>"/>
</form>
Although not sure what I need for the Form Action, if the behaviour is triggered by the button press? I've tried it with and without that form action
And then in the File Name for the behaviour, I've been trying each of:
<?php echo $row_WADAMusic['Music']; ?>
<?php echo $WA_DFP_DownloadStatus["WA_DownloadResult1"]["fileName"]; ?>
<?php echo((isset($_POST["Download"]))?$_POST["Download"]:"") ?>
But doesn't seem to do anything with any combination of the above.
Can I make sure I have those two parts correct and take it from there?
