Showing UserID in acknowledgement page
Thread begun 3/12/2013 7:21 am by ori382079 | Last modified 3/12/2013 10:23 am by Jason Byrnes | 3748 views | 7 replies |
ori382079
Hi there, I have a slight challenge here. I'll like a user to have his/her ID (which is UserID) after the registration form is submitted. This ID will be included in the thank you page for the user to take note of and keep for his/her records.
Now I have created the recordset and bound the user_Id data to the field in the thank you page but on testing it, the user_ID does not show. Please would you check for me where I have made mistake. I will really appreciate it. Please see the attached files:
you will need to store the ID in a session on the apply page.
on the apply page, change line 66:
$Result1 = mysql_query($insertSQL, $su_lokoja) or die(mysql_error());
$_SESSION['UserID'] = mysql_insert_id($su_lokoja);
then on the thank you page, you can display the id using this code:
@session_start();
echo(isset(
$_SESSION['UserID'])?$_SESSION['UserID']:"");
ori382079
Thanks Jason, but it's still not working. Though the Primary key in the table is NT_ID which I changed accordingly. See my attached files
Is the NT_ID column set to auto increment?
maybe try changing:
$_SESSION['NT_ID'] = mysql_insert_id($su_lokoja);
[php]$_SESSION['NT_ID'] = mysql_insert_id($su_lokoja);
@session_commit();[php]
ori382079
Yes, the NT_ID is set to auto increment
ok, welllll, did you try adding the session commit line?
ori382079
Hi Jason, i have tried it and there is no luck.
