Install help needed
Thread begun 8/12/2009 12:04 am by meisinga299277 | Last modified 8/14/2009 4:25 am by jenkolaka19379118 | 2682 views | 3 replies |
meisinga299277
Install help needed
Hi All
I really like to start using the data assist extensions, but I cann't seem to get the mysql gui tools proparly installed.
Do you give support on that.
Or is there some easy readabel manual for that, I looked at all the documentation from Mysql but can't get it figured out.
Tx
jenkolaka19379118
Having battled with mysql myself I know what you are going through.
However you need to provide more information e.g.
what version of mysql you are using?
Are you using wamp, mamp, xampp or mysql and apache seperately?
what exactly is happening when you try to install mysql gui tools?
Do you have phpmyadmin?
meisinga299277
Solved
Hi Jenkolaka
Had it all up and running, now the problem starts with making a resting server.
Will ask a friend off mine to give me some lessons because I got a big head ache yesteray after trying for 10 hours.
Tx for the help any way.
The problem was that I couldn't use localhost for administrator nut had to use the IP address.
Martijn
jenkolaka19379118
Glad I could be of help,
Hope your friend can help you, if not describe your problem in detail here and I might be able to help you with your testing server.
