Security Issue Help
Thread begun 3/11/2013 10:35 am by johna1964 | Last modified 3/11/2013 11:52 am by johna1964 | 2000 views | 4 replies |
johna1964
Security Issue Help
My ecart pages are not being forced to https (ssl) - please help.
Thought I found the solution
showthread.php?t=13554&highlight=force+cart+pages+https
I tried both of the suggestions from this link. Neither of them work.
I don't understand what I need to do.
The files are included. As it is now, no one is able to even view the checkout page.
Please help.
Thank you!
johna1964
your best bet is to use mod rewrite with htaccess if you are on an apache hosting platform:
force-ssl-htaccess.html
johna1964
Hi Jason,
Thank you.
Can you explain how to specify the particular pages involved in the htaccess file?
The ecart pages are not in a specified folder.
The cart page in only file being forced to https. I have idea why the others do not do so.
It there a way to create the http to https redirect through the WA software?
Thank you!
With the htaccess, can it use a direct file path for the specific page? For example
RewriteEngine On RewriteCond %{SERVER_PORT} 80 RewriteRule ^(.*)$ $1 [R,L]
This is not working either.
Is there a way to force only the checkout pages?
johna1964
you could create a rule specific to each page that should be under SSL:
RewriteCond %{HTTPS} off
RewriteCond %{REQUEST_URI} /checkout.php
RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI} [L]
RewriteCond %{REQUEST_URI} /confirm.php
etc....
johna1964
Hi Jason,
This works perfectly!
What a relief!
Thank you!
johna1964
