XSS protection
Thread begun 3/11/2013 7:09 am by Cologne | Last modified 3/11/2013 3:44 pm by Jason Byrnes | 4687 views | 9 replies |
Cologne
XSS protection
my test website maryjane was blocked on a server cause of XSS.
Now I red some articles about XSS.
Is it possible that it belongs to the FRAMEWORK includes?
How can I test if my page is XSS safe?
Any help? Suggestions?
Cheers,
Denis
I would need to see the scan report to tell why that page failed.
normally it happens if you write a URL variable value to the page without scrubbing it using htmlentities. for example:
<php echo(isset($_POST['postval'])?htmlentities($_POST['postval'], ENT_QUOTES):""); ?>
Cologne
Hi Jason,
now I am a bit afraid. In my backend I let the use insert their website. I check it with the server validation URL.
Will this protect my site or do I need to have more validation?
I tried to enter something like band.php?i=service and it works, I thought this is dangerous :-(
Before I have to rebuild my backend I need to know what protection is allready in the WA dataassist and databridge?
Cheers,
Denis
ps. I dont have any protocol.
in the insert record behavior that stores the website address, when you select the form element bindings, set the formating option to HTML Encode.
Cologne
Hi Jason,
I think I will allways use the "htmlentities" before insert inth the datebase.
If the links dont work, the use has to change.
I check if its email or url, then I store both with "htmlentities"
Will this be the best solution?
Cheers,
Denis
yes, that would work
Cologne
hmm, so if I use "htmlentities" it doesnt matter what the user puts into my form fields?
For example I want the street and city, I dont need worry when I insert with "htmlentities"?
Sorry for asking that much, cause, if so, I can use less code, cause I dont need all that validation.
Am I right, when I say, I use the WA validation to FORCE the user to insert LIKE I want.
If I dont want to foce the useer, it allright only to use "htmlentities" in the DA wizzard?
Is the WA "htmlentities" with "ENT_QUOTES"
can you also explaine the diffrence between:
<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>
and
<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>?<?php echo preg_replace("/^&/", "", preg_replace("/&?invalid=true/", "", $_SERVER["QUERY_STRING"])); ?>
Which is better to use?
Cheers,
Denis
html entities will convert tags to html entities
so if the user enters:
<bold>John Doe</bold>
and you convert that using HTML Entities,
it will insert to the database as:
&lt;bold&gt;John Doe&lt;/bold&gt;
Cologne
How do I use it with universal Email?
same way, when you add a binding for a from address or to address, set the formatting to use HTML Encodeing
