Universal email thank you region
Thread begun 3/10/2013 6:37 pm by info145869 | Last modified 8/23/2013 11:55 am by Jason Byrnes | 3355 views | 7 replies |
info145869
Hi
Is there somewhere a tutorial that when a form is submitted i do not have to create a separate thank you page but can just submit the form to itself and have a region above the form displaying that the form has been submitted.
Thanks for any help
In Universal Email, you could set the Go To Page to page with the form on it, and pass a URL variable:
pagename.php?sent=true
open the bindings panel, and create a new binding for the URL variable. Click the plus button select URL Variable. for the name enter "sent" (without the quotes).
then you could type the thank you message on the page, select it and add the WEbAssist Show Region Utility.
Open the server behaviors panel, click the plus button and select WebAssist -> Utilities -> Show region.
click the lightning bolt next to the if setting and select the sent URL variable binding.
set IS to "equal To"
and for the value enter "true" (without quotes)
info145869
Tried this and it doesn't work. Get the following error
Notice: Undefined index: sent in D:\Domains\testdomain.com.com\wwwroot\contact.php
the error should also report a line number?
send a copy of the contact.php page so I can see the code.
info145869
Its 184
ok, line 184 is:
if ("".$_GET['sent'] ."" == "true") {
change that to:
if ("".isset($_GET['sent'])?$_GET['sent']:"" ."" == "true") {
info145869
Thanks i try this . Question.
That is part of the "show if" region. does this mean the extension is not working as should ?
the extension is working fine, it is just that you have your servers error reporting level set to includeNotices, Notices are not really problems.
