newbie help with captcha element
Thread begun 3/08/2013 5:22 am by secure377208 | Last modified 3/08/2013 7:42 am by Jason Byrnes | 1725 views | 3 replies |
secure377208
I have tried adding WA captcha to a form and get to the point where I need to set up the vailidation, following the steps on the tutorial I get to where I select server variable by clicking the lightning icon and I see session, captcha_security_code_1 and underneath the forms[0] but I do not see the Server Variables entry as shown in the tutorial. I have just set up a local testing server using xampp specifically to use this facility but although I believe I have set it up correctly I am getting the above issue.
It is almost as though there is a step missing in the tutorial, how do I get the "Server Variables" element to appear in the panel.
Any help with this is appreciated.
Thanks in advance
What server variables do you see under the Forms [0] collection?
What is the name of the captcha form element on the page, That should be listed under the Form binding group.
if you need more assistance, please send a screen shoot of the bindings you see and a copy of the page.
secure377208
captcha issue
Hi Jason,
Thanks for the prompt response. If I drop down the forms[0] list I can see all the form fields listed which includes an item listed as Security_Code_1. In addition there are three entries hdwemail - hdwok and hdwnook which are a part of the php form script. I have attached a couple of screenshots of the top part of this list I have also attached the code for the php page. As you will see from the screenshots I am not seeing the server variables element.
In case it helps the form uses Form2mail to process the submission.
Hope this provides all the info you need.
Regards
