Date Picker Not Working as Plug In
Thread begun 3/07/2013 2:29 pm by CUAD | Last modified 3/08/2013 7:27 am by Willi Schneider | 3807 views | 3 replies |
CUAD
I have a page with a search form. I then used that page as a plugin on another page but the date picker will not work? The original page is searchForm.php and the page with the plugin is search.php. Just wondering what may be causing this issue?
Willi Schneider
Originally Said By: srahrich
  I have a page with a search form. I then used that page as a plugin on another page but the date picker will not work? The original page is searchForm.php and the page with the plugin is www.cuadmemo.com/search.php. Just wondering what may be causing this issue?
Hi
You have two references to the jQuery library in your page:
In line 16/17 you have a reference to the WA version:
<script type="text/javascript" src="webassist/jquery/jquery.js"></script> <script type="text/javascript" src="webassist/jquery/jquery-ui.js"></script>
In line 57 of your source code you have:
<script src="js/jquery-1.4.2.js" type="text/javascript"></script>
...which is causing the problem.
Try to comment that out and see, if it works.
HTH
Willi
CUAD
I was wondering if I had some code somewhere that was duplicating. That worked, thanks for the help.
Willi Schneider
Hi
Glad to hear it works...
