Preset Manager is missing
Thread begun 3/07/2013 12:39 pm by nsisler401033 | Last modified 8/14/2013 8:44 am by Jason Byrnes | 4174 views | 7 replies |
nsisler401033
After installing design extender, the preset manager has disappeared.
The Preset Manager is under the WebAssist Menu.
if you continue to have a problem, please post back details about other extensions that are installed, including the version numbers.
YellowCircleWeb
I can't see the preset manager either. I have the latest versions of Design Extender, Databridge and eCart installed. I've looked in every option in the webassist menu in dreamweaver and it's definitely not showing??
It should be under the webassist menu
send a screen shot of the items your see listed in the webassist menu please.
info4753
Same here. After installing your extensions in DW CC, no preset manager and no presets.
Do you have eCart 5 installed? Try Looking under the Insert -> WebAssist menu.
info4753
Thx. The menu is there. But where are all my presets? Can I import them from CS6?
Use the preset manager in DW CS6 to export your presets, then you can import them to DW CC using the DW CC preset manager.
