CMS Builder not working after migrating to new server
Thread begun 3/07/2013 12:36 pm by ssbinghampl428850 | Last modified 3/07/2013 1:56 pm by Jason Byrnes | 3580 views | 3 replies |
ssbinghampl428850
I have moved a website that used power cms to new hosting (same domain name) and are now seeing the following errors.
When trying to log in via log in page (eg. powercms) I get -
Warning: mysql_pconnect() [function.mysql-pconnect]: Access denied for user 'backpac_admin'@'localhost' (using password: YES) in /home/baba1754/public_html/powercms/Connections/PowerCMSConnection.php on line 9
Fatal error: Access denied for user 'backpac_admin'@'localhost' (using password: YES) in /home/baba1754/public_html/powercms/Connections/PowerCMSConnection.php on line 9
And where the content on the page used to appear I get -
Warning: include(/home/backpac/public_html/powercms/WA_CMS/addtosite.php) [function.include]: failed to open stream: No such file or directory in /home/baba1754/public_html/gorideawaveactivities.php on line 142
Warning: include() [function.include]: Failed opening '/home/backpac/public_html/powercms/WA_CMS/addtosite.php' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/baba1754/public_html/gorideawaveactivities.php on line 142
Fatal error: Call to undefined function WA_getCMSContent() in /home/baba1754/public_html/gorideawaveactivities.php on line 14
I think that it may be something to do with the file path changing, but not really sure.
Any help with this would be greatly appreciated.
you will need to update the Connections/PowerCMSConnection.php file to use the correct details for connecting to the new MySQL Server.
also, when you add a content area to the page, the path to the WA_CMS/addtosite.php page is generated based on that servers file system,
if you open the PCMS Admin section and select a content area, then view the Developer notes ., it will show the include path for the WA_CMS/addtosite.php file for the server you are on.
you will need to update the code on your pages to use that new path.
ssbinghampl428850
Hi Jason,
Thanks for the prompt reply. I have changed the PowerCMSConnections file using what I believe to be the correct info but are still getting the same error message when attempting to log in.
Below is the PowerCMSConnections file. Can you tell me where to find the correct usernames and password? (I have replaced them with ???)
# FileName="Connection_php_mysql.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_PowerCMSConnection = "localhost";
$database_PowerCMSConnection = "?????????_cms";
$username_PowerCMSConnection = "?????????_admin";
$password_PowerCMSConnection = "?????????";
$PowerCMSConnection = mysql_pconnect($hostname_PowerCMSConnection, $username_PowerCMSConnection, $password_PowerCMSConnection) or trigger_error(mysql_error(),E_USER_ERROR);
Sorry for my lack of knowledge on this
If it giving the:
error, it means that you do not have the correct username or password to access the MySQL Server.
