Multiple PHP.INI files
Thread begun 8/11/2009 8:07 pm by robp295024 | Last modified 8/26/2009 3:28 pm by Jason Byrnes | 5395 views | 5 replies |
robp295024
Apologies if this a really stupid/obvious thing... I am afflicted by having to convert from ASP/Access to PHP/MySQL and am having "newbie issues"... :(
This problem arose after installing PowerStore on to my server.
The Contact Form App from WA stopped working with a "500 error"
The only culprit I can determine is a problem in the 2 apps and PHP.
basically, my question is how do you maintain 2 (or more) "different" INI files for PHP on a IIS 7.0 server?
Thanks in advance...
Rob
Your PHP setup should only load a single ini file for the settings. It will look in the C:\windows directory and your local install directory for php. If you create a phpinfo page it will show you which ini file is loaded. An info page is any php page that has this code in it:
<?php phpinfo(); ?>
If you don't have one already create a new page and have just this in it. You should be able to see the setup info for your php including the loaded ini file. If you cannot view the page then this would indicate that there is an issue with your server setup in IIS. If you do get an error here post back with the exact error message text if you need help with it.
dvpapa51386826
Problems with installing PHP
Hello everyone, I have experince in dreamweaver and flash CS3, creating basic or static web pages, and animation for web designs in the internet. But I wanted to break away from just the ordinary web design and try to create dynamic web pages, by using PHP & MySQL...
Well I have my computer set up to do so, but I cant seem to manage on installing PHP nor MySQL...I already have a Wampserver installed, along with Apache, But from there on I am stomped on what to do next...I tried doing dreamweaver toutorial on having dreamweaver on how to create php pages, but I still can not view my work when executing F12...Any thought's on that please?
[examples: www.cmsdemo.eunet.gr/ is just the animation on the header....(2nd)...djp-design.com/ this is just a sight I did for fun with]
Wamp Creates the folder:
c:\Program Files\wamp\wwwroot
as the root of the website.
Files in this folders are served to the browser at the address:
localhost.
Create a sub directory of that folder for you Dreamweaver site such as:
c:\Program Files\wamp\wwwroot\myWebsite
On the Local Info tab of the site definition set the Local Root Folder to this locatyion.
On the Testing Server Tab, set the server model to PHP MySQL and set the Access to local / Network.
The testing server folder should also be set to:
and the URL Prefix should be:
myWebsite
robp295024
reply for Eric
I tried that phpinfo page Eric; created a new blank page in my main site - but it always displays as a blank page.
IIS says PHP is installed etc - so am in a bit of a quandary
Rob
When a php page displays blank, it means that a php error has occurred but the host has turned of error reporting. Some host's will allow error reporting to be turned on for debugging purposes by placing the following code block at the 1st line of your page:
error_reporting
(E_ALL);
