Reference Error: The Server Language is not Defined
Thread begun 3/06/2013 5:00 am by salaroche | Last modified 3/07/2013 10:15 am by salaroche | 6776 views | 21 replies |
salaroche
Hi:
I'm trying to create a Contact form using CSS Form Builder and I'm getting an error message saying "Error finding Server Behaviors in Inspector. Reference error: The server language is not defined". That's a message I get while trying to edit the Form in DW.
When trying to test the form online I get the following error message:
Warning: require_once(webassist/form_validations/wavt_scripts_php.php) [function.require-once]: failed to open stream: No such file or directory in D:\hshome\c309340\dennfree.salaroche.com\Email.php on line 1
Fatal error: require_once() [function.require]: Failed opening required 'webassist/form_validations/wavt_scripts_php.php' (include_path='.;c:\Program Files\HSphere\3rdparty\PHP\PHP53\pear') in D:\hshome\c309340\dennfree.salaroche.com\Email.php on line 1
Obviously there's something I'm not doing right, but what is it? Any suggestions?
Thank you for your attention.
For the initial error, have you tried Deleting the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
if you continue to get the error, edit your site definition, and make sure that in the testing server settings, you have set the application modal to PHP.
for the error in the browser, make sure that you have uploaded the webassist/form_validations/wavt_scripts_php.php file to the server.
salaroche
Jason:
Thak you for your reply. I did as you suggested, but when I try to open the Edit Form I get the following error message: Error initializing Add Form UI: Reference Error: The Server Language is not Defined. Then the fields in the "Add Form" window are blank.
Edit Design opens well and Edit Contents too.
Any suggestions?
What extensions including the version numbers are installed?
salaroche
Jason:
I resinstalled CSS Form Builder and that fixed the problem with DW. I also uploaded the validation scripts as you suggested and the Contact form is now loading well. However, the form is not sending emails.
I've noticed I haven't entered SMTP Server name and Port number anywhere, is that OK?
That depends on your host. For some hosts, you don't need to enter an SMTP Server name or port, on other hosts you do.
salaroche
Jason:
I entered SMPT Server name (127.0.0.1) and Port Number (25) as the guys at my host suggested, but the form is still not sending emails. Any suggestions?
salaroche
Jason:
Here's how the guys at iX Webhosting fixed the problem: "I have created .htaccess file on main domain's folder and added an envelope sender configuration there". Now the form is sending emails.
Was that the only way to fix the problem?
salaroche
Jason:
It was false success. The form is back to not sending emails.
salaroche
Jason:
Any suggestions on how to make the Contact form send emails will be highly appreciated. And I have to go because it is 3:15 AM on Thursday here in China and I got things to do later today.
Thank you for your attention and looking forward to reading you reply later today.
