Adding Form Variables Causes Email to Fail
Thread begun 3/05/2013 4:49 am by jennifersaas446228 | Last modified 3/05/2013 6:59 am by Jason Byrnes | 1414 views | 2 replies |
jennifersaas446228
Hi there,
So after hours of trying to figure out what's happening here, I'm at a complete lost.
I have a registration form that is filled out, validated, then entered into a mySQL database using Dreamweaver's Insert Record. I have Universal Email set up to send out a confirmation thank you email to the email addy that was entered into the form. All good there.
The problem I'm running into is that if I try to put any post variables into the body of the email, the email fails and doesn't send. If I just use text only, it works. The confusing part is that the To email addy is a post variable and that works fine (though I know that value is kept in a different file).
Any help would be really, very appreciated!
*****Here's the code from the top of my form page:*****
if (($_SERVER["REQUEST_METHOD"] == "POST")) {
//WA Universal Email object="Mail"
//Send Loop Once Per Entry
$RecipientEmail = "".$_POST["EmailAddy"] ."";include("WA_Universal_Email/WAUE_event_rego_1.php");
//Send Mail All Entries
if ("event_rego2.php"!="") {
header("Location: event_rego2.php");
*****Here's the form field I'm using to test with*****
<input type="text" name="HName" value="" size="32" tabindex="4">
*****Here's the WAUE_event_rego_1.php code that I have:*****
$MailAttachments = "";
$MailBCC = "";
$MailCC = "";
$MailTo = "";
$MailBodyFormat = "";
$MailBody = "";
$MailImportance = "";
$MailFrom = "hashcash@carolinatrash.com";
$MailSubject = "You Are Now Registered for Carolina Trash Cheap Mexican Campout 2013";
$_SERVER["QUERY_STRING"] = "";
//Global Variables
$WA_MailObject = WAUE_Definition("mail.jennifersaas.com","25","hashcash@carolinatrash.com","Carolina Trash Hash House Harriers","","");
if ($RecipientEmail) {
$WA_MailObject = WAUE_AddRecipient($WA_MailObject,$RecipientEmail);
else {
//To Entries
//Attachment Entries
//BCC Entries
$WA_MailObject = WAUE_AddBCC($WA_MailObject,"wolfie@carolinatrash.com");
$WA_MailObject = WAUE_AddBCC($WA_MailObject,"gm@carolinatrash.com");
$WA_MailObject = WAUE_AddBCC($WA_MailObject,"hashcash@carolinatrash.com");
//CC Entries
//Body Format
$WA_MailObject = WAUE_BodyFormat($WA_MailObject,0);
//Set Importance
$WA_MailObject = WAUE_SetImportance($WA_MailObject,"3");
//Start Mail Body
$MailBody = $MailBody . "<html><head></head><body>";
$MailBody = $MailBody . "<p>Thank you for registering!</p>\r\n";
$MailBody = $MailBody . "<p>";
$MailBody = $MailBody . ((isset($_POST["HName"]))?$_POST["HName"]:"");
$MailBody = $MailBody . "</p>\r\n";
$MailBody = $MailBody . "</body></html>";
//End Mail Body
$WA_MailObject = WAUE_SendMail($WA_MailObject,$MailAttachments,$MailBCC,$MailCC,$MailTo,$MailImportance,$MailFrom,$MailSubject,$MailBody);
$WA_MailObject = null;
jennifersaas446228
Not sure what I did...
But it's working now lol. Been trying such small changes, was doing them in batches and not sure which of them fixed things but it's now working.
Glad to hear you have it working.
The code you include in your message is incomplete, so it's pretty close to impossible to tell what the problem may have been, in the future, please compress the PHP page to a zip file to include the complete code.
one thing i see in your message, is that the to address is using a form element named "EmailAddy"
the you post the form field your testing with which does not have the same name, it is named "HName"
so perhaps the fix that worked was that you renamed that field or added another field named "EmailAddy"
