Datepicker and UK Date format
Thread begun 3/04/2013 9:25 am by Meic Delwedd | Last modified 3/04/2013 11:29 am by Jason Byrnes | 1960 views | 2 replies |
Meic Delwedd
I'm using the Databridge add-on and have got most of what I need working.
One issue I'm having is when I add a new Datepicker to my forms, when selecting the format I want (dd/mm/yyyy), I am getting Invalid Format when selecting any day that is higher than the 12th day of the year, which I presume is because the validation in the SpryValidationTextField.js thinks that the day I am selecting is a month and won't allow it.
Is this a known issue? How can I get around/fix it?
Thanks.
Hi did you see my post earlier? showthread.php?t=30300
you need to make sure your storing the date in reverse order in the database. For example: 2013-03-03 20:02:39, so in the date picker server behaviour under "Format" chose yyyy-mm-dd from the drop down list since it needs to match the format stored in the MySQL database.
My webassist forum link above gives a more in depth guide to date usage.
Chris
@Meic Delwedd:
If you continue to have a problem, please send a copy of the page.
