Error in code on insert page
Thread begun 3/04/2013 9:13 am by Jonas | Last modified 3/04/2013 2:01 pm by Jason Byrnes | 4003 views | 9 replies |
Jonas
I get error message when I run an insert page that Data Assist created. Other insert pages work fine but not this one. Attached screenshot shows the error message. The page can be accessed at produkter_insert.php.
looks to me like the require once line for the connection is in the wrong place, but i would need to see the code in order to tell for certain.
Jonas
webaddress
Is not the www address enough?
no, the www address does not allow me to see the php source code, i would need a copy of the php page in a zip archive to see the php source code.
Jonas
comes here
Sure, here it is!
This is the results page?
I thought the problem was with the insert page?
Jonas
Thanks for the note! Here comes the insert page.
move the following code at lines 15 - 16:
<?php require_once('../Connections/loopia.php'); ?>
require_once("../webassist/database_management/wa_appbuilder_php.php"); ?>
to line 1.
Jonas
I'm a little curious how the problem has occurred! Because I have created this file a few times with the same result. Is it a bug? Shall I in that case report this or are you doing this?
I cant reproduce the problem of the code being generated in the wrong place, but have logged a bug that it happens in some instances.
