Uploading images
Thread begun 3/01/2013 1:12 pm by john70964 | Last modified 3/01/2013 2:12 pm by Jason Byrnes | 1787 views | 4 replies |
john70964
Uploading images
I am using DataBridge Image Upload
I have an upload form which has 10 browse buttons.
I have been using this locally with some practice images size around 30 kb each with no problems.
I tried increasing the upload with images around 3mbytes each as I anticipated some users will do.
I find that I can upload 2 images of this size but thereafter the upload fails.
Is this to be expected and can it be rectified? Maybe I have to use 5 pages. Seems rather clumsy.
there are a number of settings that will effect the allowed upload file size in the php.ini file
one likely problem you are running into is the post max size.
for a full list of settings in the php.ini file that effect file upload see the following page:
wap_upload.asp?page=php2
john70964
Hi Jason
Do I really have to understand all of that to use the upload behaviour or is there a section that applies. Seems rather daunting.
john70964
I found
; Maximum size of POST data that PHP will accept.
; post-max-size
post_max_size = 8M
If I change that to 30 or 40 Mega Bytes on my local machine will that work?
Then I wonder if this can be carried out at the server?
Thank you
you will need to contact the host to have them increase the post max size for you.
