HELP The form wont work!!!
Thread begun 3/01/2013 9:28 am by tdhkfinkel424121 | Last modified 3/01/2013 9:48 am by Jason Byrnes | 6983 views | 1 replies |
tdhkfinkel424121
I have created a complicated form with CSS Form Builder and it seems to only work in some servers.
In IE and in Lunascape the form wont load at all but in Chrome and Firefox there's no problem.
How do I get it to work in ALL servers?
IE, Chrome, and Firefox are web browsers, not web servers.
Where this is a browser specific issue, i will need to be able to see the problem to troubleshoot.
Please send a link where i can see the problem to troubleshoot the cause.
tdhkfinkel424121
Browser Issue
Hi Jason,
Sorry for the tech wording error...
Anyway the home page is:
www.hinghamshipyardmarinas.com/
There's a drop down menu bar (that may work-or not) that has a link to the online license form or you can go to:
marina-dockage-storage.html
And click on the on line license form link there
And below is the form it self
license_form1Web2A.php
Viewing the source code of your page page, I see the following:
<script language="javascript" type="text/javascript"  />
function process3Shirts()
var quantity = parseInt(document.HSMLicense_BrassyHSM_BrassyHSM.txt3ShirtQuantity.value);
var unitPrice = parseFloat(document.HSMLicense_BrassyHSM_BrassyHSM.txt3ShirtUnitPrice.value);
var total = unitPrice * quantity;
document.HSMLicense_BrassyHSM_BrassyHSM.txt3ShirtTotal.value = total.toFixed(2);
</script>
there is a missing closing comment. it should be:
</script>
tdhkfinkel424121
Hi Jason,
Thank you-Just when you think you dotted all the" i "s....
Another issue I'm wrestling with is my spry menu bar in IE.
I'm wondering if you have any ideas how I can get the drop downs work on the menu bar with out having to recreate it.? Or is there a webassist that is more suited for that type of menu bar in IE9?
Thanks Again
your page is missing the doctype tag.
without a doctype tag, IE will use quirks mode to display the page. Quirks mode uses the IE 5 rendering engine which does support the CSS Elements needed for the spry menu to display the sub menus.
add the following doctype tag just before the opening <html> tag:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
Just to give my 2 cents here, I usually use this doctype as standard for websites:
<!DOCTYPE HTML>
<html>
<head>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1">
</head>
Chris
this is the HTML 5 doctype:
<!DOCTYPE HTML>
the code on the OP's page does not conform to HTML 5 standards, that is why i gave the doctype for HTML 4.0.1 transitional.
His code more closely conforms to the 4.0.1 transitional doctype rules.
but doesn't using <!DOCTYPE HTML> allow for backwards compatibility with standards in terms of browser updates? so for example if the website is still going strong in 10 years time and a new browser comes out that wont screw up because its using an old doctype?
also the IE=edge allows for the best possible features of that browser to be used right?
the doctype does not get defined by the browser.
the doctype is defined by the DTD that it is pointing to, for HTML 4.0.1, the dtd path that is used is:
meaning that IE will look to the w3.org site to determine how to display the page.
It is valid to use the HTML 5 doctype for backward compatibility, at least for now, but there is no of knowing if that will be valid in 10 years.
Programers in the '70's thought it was valid to only use 2 digit years, look how that ended up.....
I dont think relaying on the HTML 5 doctype for backwards compatibility is a very good idea.
Yes, setting the User Agent using the meta tag is a good practice too, but not necessary for
the Spry Menu to work.
