Data Assist Detail Page layout
Thread begun 3/01/2013 6:46 am by john70964 | Last modified 3/01/2013 8:06 am by Jason Byrnes | 1744 views | 3 replies |
john70964
Hello
I have an update page where titles and update boxes are all showing in a single column
I cannot see any way to change this.
Is it supposed to be like this? It seems like the styles are disconnected.
I attach a picture and a zipped file
Thank you
John
Yes, the form designs for Data Bridge are one column form designs.
you would need to modify the css and the div structure to create a 2 column form layout.
john70964
Thanks Jason
I cannot use the form like that.
Did you receive the image and the zipped file I sent?
I know I definitely sent them but cannot see them now.
Are there any tutorials for the css and div requirements?
Yes, I saw them.
No there are not any tutorials for modifying the CSS.
your best bet is to use Fire Fox with Fire Bug to pin point the CSS properties that effect the specific elements.
As a last resort, you can create the insert and update forms manually. Just make note of the form element names that are used when you recreate the form. make sure all the elements in your new form use the same names as elements in the old form.
