User Registration including User Levels
Thread begun 2/28/2013 11:58 am by greg401801 | Last modified 2/28/2013 12:22 pm by Jason Byrnes | 1432 views | 1 replies |
greg401801
I'm a relative newb. Please answer in fairly simple and specific terms. You won't insult me.
I am using DataBridge/SecurityAssist/DataAssist/Cookies, etc. I am following the "Create a Double Opt In Registration System" tutorial and video. I have run through it a couple of times, first following the steps exactly, then "playing" to see if I could modify it somewhat. I'm about to go through a third and (hopefully) final time. The first time it worked. The second time I tried adding in User Level Authentication. It didn't work. In going through the forums and support info I discovered what I think was a post that said I have to place my registration pages at the root level of my site. OK. I don't remember seeing that directive anywhere. That may be one of the reasons the second go through failed. I put the registration pages in their own folder.
Here are a series of questions that are vexing me:
1 - In creating the MySQL database it sets up, by default, a root user with username/password as root/root. For my connection I added an additional username/password of my own creation and am using that for my connection. It works fine. My question is, will leaving root/root expose my database to the world? I tried to change it (newb move) and fried MySQL. Had to reinstall MAMP and do some other stuff. Is my setup typical and secure?
2 - Do the registration.php and login.php and userupdate.php, et al, have to be at the root level of my site? My preference is to create a separate folder (also called a subdirectory, correct?) for the registration pages. I want to have all the pages that are password protected in other folders to keep the site neat and tidy.
3 - If it is a requirement to have the registration pages at the root level, is it possible to have the rest of the protected pages in folders?
I want to have User Levels for my site. Anyone who registers won't get immediate access to my protected pages. I will evaluate their registration information. If I want to give them access I will change their default User Level from 1 to 2. Level 2 users can see my pricing but that is all. Level 3 users have purchased $1K or more from me so they have access to some special stuff. Level 4 users have purchased $5K from me. And so on. The higher the User Level the better stuff they have access to. I think I need to edit the Restrict Access Rule to check for UserLevel. I tried to apply the info from the "SecurityAssist - User Level Authentication" information I downloaded. It doesn't fit exactly - remember, I'm a newb. I'm pretty sure I will need to use SecurityAssist: Authenticate User. I'm certain I will need to work with the Access Pages/Rules/Groups Managers. And I'm pretty sure there are several steps that I don't have a clue how or why to implement.
4 - Can someone tell me what to do to make the scenario above work? It seems so simple but there are so many steps. If there is a tutorial that does all this, great!! If not - Help!!
Thanks for any assistance you can provide.
1) Your Mamp server wont be accessible to the world.
2) No, registration and login pages do not have to be at the site root, they can be in a subdirectory if you like.
weh running the security assist wizard, on the manage pages tab, you can specify the subdirectory along with the page name, for example:
directoryname/login.php
3) the other protected pages can be in the site root or in any other subdirectory of your site
4) The User Level Authentication tutorial should give you a good start on this.
for your needs, you would set the default value for the userlevel column to 0, and in the security assist wizard, don't include the userlevel column on the registration page
this way, when a new person registers, the assigned user level is 0.
you will need to edit the security assist authenticate user behavior to store the user level in a session as outlined in the user level tutorial.
then create access rules based on the user levels you will use in your site.
On the pages where you make the products for a specific user level available, use the appropriate access rule.
if there is a specific part of this that you need help with, please let us know
