UserGroupID value in Registration.php defaults to 0
Thread begun 2/28/2013 11:48 am by ori382079 | Last modified 3/01/2013 11:20 am by ori382079 | 10076 views | 10 replies |
ori382079
I created my security pages and used the UserGroupID column as the username (SU_ID) to login because this value will be generated by the client and be allocated to the users who will then use it to register their membership.
I redefined the properties of this field in webassist, but whatever value entered into it, it shows '0' in the database table. Also I have amended the column type in the database table created by webassist 'pcms2_users ' to Varchar but still shows 0.
Please what have I done wrong. See the code in registration php
<div class="lineGroup">
<label for="Registration_group_SU_ID" class="sublabel" > SU ID:<span class="requiredIndicator">&nbsp;*</span></label>
<div class="errorGroup"> <span id="Registration_group_SU_ID_Spry"> <span>
<input id="Registration_group_SU_ID" name="Registration_group_SU_ID" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("registration","Registration_group_SU_ID"):"")); ?>" class="formTextfield_Large" tabindex="1" onBlur="hideServerError('Registration_group_SU_ID_ServerError');">
if (ValidatedField('registration','registration')) {
if ((strpos((",".ValidatedField("registration","registration").","), "," . "1" . ",") !== false || "1" == "") || (strpos((",".ValidatedField("registration","registration").","), "," . "2" . ",") !== false || "2" == "")) {
if (!(false)) {
<span class="serverInvalidState" id="Registration_group_SU_ID_ServerError">Please enter a value.</span>
<?php //WAFV_Conditional registration.php registration(1,2:)
<span class="textfieldRequiredMsg">Please enter a value.</span> </span> </span> </div>
</div>
please send a copy of the registration page so i can see the code.
ori382079
Please see attached as requested. Thanks
This page does not include a registration form or the insert record behavior?
please send a copy of the security assist registration page.
NOTE: Don't convert the page to a text file, compress the original php file to a zip archive and send the zip file.
ori382079
Please see attached zip as requested
the file you attached does not include the registration form.
i need to see the registration page that includes the registration form, the page that was created by the security assist wizard.
ori382079
Hi Jason, this is the registration page created by security assist wizard, I had to amend the labels which explains why it may not look the security assist page. Do you want me to send the accompany pages (login, logout, userupdate and forgotpassword ) ?
No, the page your are sending has no form code in it at all, it is not the security assist registration page.
There is no security assist code at all in the page you are attaching.
ori382079
Hi Jason, Sorry you are perfectly right. The security assist registration page is in my includes folder and had been sending you the wrong page . Here's the registration page..I hope!
In the Insert record behavior, the data type being used for the UserGroupID column is an integer.
Edit the insert record server behavior to change the data type for the UserGroupID column to text so that it will allow you to insert a text value.
