css for design Edit Dign error
Thread begun 2/28/2013 10:16 am by eladgraphics386618 | Last modified 7/19/2013 10:26 am by Javier | 7711 views | 40 replies |
eladgraphics386618
Hello
I am using dw6 and windows7
when I click on edit design on css form design I have this error
while executing onload in WAFB_editThem.htm, the following javascript error(s) occured
in file"WAFB-editThem"
initializeUI is not defined.
I have uninstalled the extension and re-install it but every time I click on edit under edit design I always have that error message.
Can someone please help me with this.
thanks so much.
eladgraphics
7704539200
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
eladgraphics386618
Hello
Thanks so much for the quick response.
I have tried it and it worked perfect.
Thanks for the hard and good job you guys doing.
eladgraphics
Javier
If I create the login, logout and registration from the wizard how I can change the design
you can change the design of the pages that the wizard creates by using Dreamweaver.
if you have a template, you can apply the template to the pages using Modify -> Template -> Apply template to page.
Javier
I modify the template page but the user login dont work
send a copy of the login page please, a link where i can test the registration would also help.
Javier
http://www.tekprodpwnloads.net/login.php
http://www.tekprodpwnloads.net/registration.php
i had asked for a copy of the login page also please.......
Javier
ok
