Universal Email missing picture
Thread begun 2/28/2013 8:50 am by john70964 | Last modified 4/08/2013 9:39 am by Jason Byrnes | 3987 views | 9 replies |
john70964
Good afternoon
I am using Universal email to cause an image to display in an email.
I have checked the image is present in the images folder and the correct image name is present in the database table field.
The email which is returned has all details correct except the image will not show.
The code in universal email is
<img src="http://boat-for-sale.co.uk/BoatImages/<?php echo $row_rs['Image1_250']?>" />
but the code in the email returns
<td colspan="3" style="font-size: 12px; padding: 3px;"><img src="http://boat-for-sale.co.uk/BoatImages/NoImageDot.jpg" />
I checked correctimagename.jpg and the image shows correctly
The NoImageDot.jpg is the default field name before the field is updated.
It seems the email takes the image name before the field is updated.
Can this be changed?
I am attaching the file containing the code.
Many thanks
John
most likely the code to define the recordset is before the code to perform the update.
make sure the code order is:
Update Record
Create Recordset
Send Email
john70964
Thanks Jason
I had two files with this problem the first file was corrected immediately with the reordering.
The second file creates the following messages. I checked there are no spaces in between tags.
Warning: Invalid argument supplied for foreach() in /home/jh10/boat-for-sale.co.uk/webassist/file_manipulation/helperphp.php on line 78
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/jh10/boat-for-sale.co.uk/webassist/file_manipulation/helperphp.php:78) in /home/jh10/boat-for-sale.co.uk/webassist/email/mail_php.php on line 274
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/jh10/boat-for-sale.co.uk/webassist/file_manipulation/helperphp.php:78) in /home/jh10/boat-for-sale.co.uk/webassist/email/mail_php.php on line 274
Warning: Cannot modify header information - headers already sent by (output started at /home/jh10/boat-for-sale.co.uk/webassist/file_manipulation/helperphp.php:78) in /home/jh10/boat-for-sale.co.uk/BoatAds180/boat_insert_images.php on line 386
I am attaching the zipped file
to help troubleshoot, add the following code at line 1:
if(isset($_FILES)) {
var_dump($_FILES);
and post back the result.
john70964
If I test on my local PC its OK
If I test on the remote server I get
The message is:
array(10) { ["Image1"]=> array(5) { ["name"]=> string(8) "1_45.jpg" ["type"]=> string(10) "image/jpeg" ["tmp_name"]=> string(14) "/tmp/phpt7Ynat" ["error"]=> int(0) ["size"]=> int(18958) } ["Image2"]=> array(5) { ["name"]=> string(0) "" ["type"]=> string(0) "" ["tmp_name"]=> string(0) "" ["error"]=> int(4) ["size"]=> int(0) } ["image3"]=> array(5) { ["name"]=> string(0) "" ["type"]=> string(0) "" ["tmp_name"]=> string(0) "" ["error"]=> int(4) ["size"]=> int(0) } ["image4"]=> array(5) { ["name"]=> string(0) "" ["type"]=> string(0) "" ["tmp_name"]=> string(0) "" ["error"]=> int(4) ["size"]=> int(0) } ["image5"]=> array(5) { ["name"]=> string(0) "" ["type"]=> string(0) "" ["tmp_name"]=> string(0) "" ["error"]=> int(4) ["size"]=> int(0) } ["image6"]=> array(5) { ["name"]=> string(0) "" ["type"]=> string(0) "" ["tmp_name"]=> string(0) "" ["error"]=> int(4) ["size"]=> int(0) } ["image7"]=> array(5) { ["name"]=> string(0) "" ["type"]=> string(0) "" ["tmp_name"]=> string(0) "" ["error"]=> int(4) ["size"]=> int(0) } ["image8"]=> array(5) { ["name"]=> string(0) "" ["type"]=> string(0) "" ["tmp_name"]=> string(0) "" ["error"]=> int(4) ["size"]=> int(0) } ["image9"]=> array(5) { ["name"]=> string(0) "" ["type"]=> string(0) "" ["tmp_name"]=> string(0) "" ["error"]=> int(4) ["size"]=> int(0) } ["image10"]=> array(5) { ["name"]=> string(0) "" ["type"]=> string(0) "" ["tmp_name"]=> string(0) "" ["error"]=> int(4) ["size"]=> int(0) } }
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/jh10/boat-for-sale.co.uk/BoatAds180/boat_insert_images.php:3) in /home/jh10/boat-for-sale.co.uk/webassist/email/mail_php.php on line 274
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/jh10/boat-for-sale.co.uk/BoatAds180/boat_insert_images.php:3) in /home/jh10/boat-for-sale.co.uk/webassist/email/mail_php.php on line 274
Warning: Cannot modify header information - headers already sent by (output started at /home/jh10/boat-for-sale.co.uk/BoatAds180/boat_insert_images.php:3) in /home/jh10/boat-for-sale.co.uk/BoatAds180/boat_insert_images.php on line 391
did you select a file for all of the file fields? or only for the first one?
could be that you are running into server limitations for the max input time setting, or the post max size setting or another of the php.ini settings that effect file uploading.
for a list of those settings, see this page:
wap_upload.asp?page=php2
john70964
I am selecting only one file for the upload in this case although anyone could select upto 10 files.
Its strange because the another upload file which is almost the same completes with no problems.
The file I am uploading is only about 82 kb
john70964
When I moved the code to create the following order
Update Record
Create Recordset
Send Email
I seem to have moved some incorrect code.
Jason kindly corrected this for me.
Thank you Jason
