How to style Results Page created via DataBridge
Thread begun 2/27/2013 11:43 am by dlovas275157 | Last modified 3/01/2013 2:48 pm by dlovas275157 | 5879 views | 8 replies |
dlovas275157
How do I create my own page design to use on my DataAssist Pages?
I see how to style the buttons within the dialog windows, but where can I style the forms and results page?
I need to change fonts, colors or text and alternate rows, shapes of add/edit/delete buttons, add padding/margins in areas to give the results table a better overall style.
The existing themes are useless "Hornet, Brassy, Cool, etc" - I just need a basic theme which I guess I need to somehow create on my own.
Looked through all the documentation, please let me know what I am missing?
Create a Form design Using Form Builder and save the design as a preset.
you can then select that preset using the Data Assist create pages wizard.
dlovas275157
Still not working ...
I created a form style via:
WebAssist > Forms > Insert New Form
(see 1st screenshot)
Then when I goto
WebAssist > Database > DataAssist Pages
the preset does not appear.
(see 2nd screenshot)
Any ideas, why its not showing up. Very complicated process to style these forms now.
Select the Unstyled Preset, the click the edit button to select the form Preset. you can then select the button preset to use with the form preset and save that as a DA Page Layout preset.
dlovas275157
When trying to edit my Form Settings inside CSS Form Builder, I get the following error:
Error Generating Preview: TypeError:
DWfile.getAttributes(orig) has no properties
Other error when choosing the Form Builder design I want to use inside the DataAsisst Wizard:
Error generating form:
TypeError: this.themeArray has no properties
I have reinstalled my extensions, and the same errors.
export the design preset you are using and attach that to your message so i can try to reproduce the errors.
dlovas275157
Jason,
Attached is my exported form design preset.
Thanks for looking into this issue further.
-Daniel
here is an updated copy of the Configuration/Shared/WebAssist/Services/fb_shared_functions.js fi;e that should correct those errors.
The fix will be included in the next update that is released.
dlovas275157
Jason,
Thanks for that config file. That fixed it.
One more question... I cannot seem to find how to control the appearance of the pagination arrows on the results page. See attached screenshot showing the specific pagination arrows I am referring to.
I would like to use just unstyled form button, or be able to add my own pngs for these as well. Can this be done?
the navigation buttons, you would need to edit after the pages are created.
you could define your own custom classes with the desired stylings for the buttons, then edit the button tags to change the assigned classes to your custom defined classes.
