WebAssist dialogue box tabs not showing text in CS6
Thread begun 2/27/2013 11:30 am by derekmparker375520 | Last modified 2/27/2013 2:05 pm by Jason Byrnes | 5688 views | 9 replies |
derekmparker375520
I'm using Dreamweaver CS6 and whenever I open a WebAssist dialogue box, there are no headings on the tabs. I have attached a sample, any ideas why this is happening?
What extensions, including the version numbers are installed?
What is your OS?
derekmparker375520
Data Bridge 1.1.2 using Mac OS 10.8.2
Uninstall 1.1.2 and instal the newer 1.1.3 version from the download center.
aslo, Delete the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
derekmparker375520
No luck, it's still not showing. I have some stand alone extensions still installed on CS3 like Menu Writer and Power CMS Builder and it shows up fine for those. I tried installing Data Bridge in the CS3 extensions manager to see if it works there, but it just crashes.
when i asked what extensions you had in stalled, i was asking for a full listing of the extensions that where installed including any of the stand alone ones.
The stand alone extensions are not compatible with DW CS6, only eCart 5, Free Tools, Design Extender, and Data Bridge are compatible with DW CS6.
derekmparker375520
For CS6, I have Design Extender 1.1.1, Free Tools 1.0.2, Data Bridge 1.1.3 and eCart 5.0.6.
For CS3 I have PowerCMS, CSS Menu Writer, Captcha, Datepicker and Form Validation. I'm not sure what versions of each because the extension manager for CS3 crashes whenever I open it.
in CS 6, what order did you install the extensions in?
Data Bridge should be installed last. I Like to install in this order:
eCart
Free Tools
Design Extender
Data Bridge
for cs3, you may need to recreate the users configuration folder, see step 10 of the dreamweaver troubleshooting guide:
troubleshooting-dreamweaver-windows.html#main_userConfigFolder
derekmparker375520
I don't remember, so I just uninstalled them and reinstalled in that order and it's still not showing up.
