Adding fields to an already created form with the Form Builder
Thread begun 2/27/2013 8:38 am by sandy170299 | Last modified 2/27/2013 9:14 am by Jason Byrnes | 1082 views | 1 replies |
sandy170299
Is there an easy way to add extra fields to an existing form created with the Form Builder, without having to go into the code and copy and paste existing fields? It was easy when it was done using a table format. Thank you.
you would need to manually add the Divs to contain the new form element to the page, then go to Insert -> Forms -> and select the element type to insert the new element.
