password + date (password expires on date)
Thread begun 2/26/2013 3:31 pm by gzirfas374932 | Last modified 2/26/2013 5:27 pm by gzirfas374932 | 1615 views | 2 replies |
gzirfas374932
I have looked thru archived SA stuff and can't find what I need. I have a table with username, userpass and date (xxx-xx-xx) with two records. the first user/password does not expire, the second one expires on a certain date. Looked up membership stuff, User groups? Basically user 1 has access forever, user 2 only has access until a certain date, then the login should fail. Can you give me a link or a direction to go?
in this thread, i give an example of how to create a rule to allow access for 14 days:
showthread.php?t=29909
you can use that as a guide to get started.
Where some users will not have time restricted access, you will need to add some custom code to set the registration date session to the current date if they are an unrestricted user level.
gzirfas374932
Excellent, thanks. Will plow thru it.
