Dropdown grandchild to display all record fields
Thread begun 2/26/2013 3:01 pm by ori382079 | Last modified 2/28/2013 10:59 am by ori382079 | 2534 views | 4 replies |
ori382079
I have successfully created a third tier dynamic dropdown which is working but my challenge is that when the grandchild is selected , I want the submit action to display the detail page of the grandchild. Please how do I accomplish it.
on the under2.php page, create a recordset to to query the courses table and filter the ID column using the Courses post variable.
ori382079
Re:Dropdown grandchild to display all record fields
Hi Jason, I'm a bit confused here, the under2.php already has a recordset for courses and the filter code is as follows:
SELECT *
FROM courses
WHERE csrID = colname
colname:
Name; colname
Type:integer
Default value: -1
Run-time value :$_GET['csrID']
When the script is run the following is the resulting URL:
"http://localhost/SU/admission/includes/under2.php?Courses=1&submit=submit"
Please where I'm getting it wrong?
your form uses the post method:
<form name="form1" method="post" action="under2.php?id=$rsCourses.csrID" >
and the name for the courses select list is "Courses":
select name="Courses" size="1" class="boxLen" id="Courses">
so in the recordset, the run time value for the colname variable should be:
$_POST['Courses']
ori382079
Thanks Jason, I have made the correction and it works as expected.
