Login, Restricted Area, &randomStringRegistration group
Thread begun 2/26/2013 5:50 am by deanmale2001272549 | Last modified 3/02/2013 9:20 am by deanmale2001272549 | 9263 views | 15 replies |
deanmale2001272549
Thank You!
login.php
Fatal error: Call to undefined function WA_Auth_RulePasses() in /home/content/32/9092632/html/login.php on line 126
This is Line 126: <?php if(WA_Auth_RulePasses("Validated form")){ // Begin Show Region ?>
preferences.php (My Name for User Area- Restricted Access) which resolved to:
userupdate.php?accesscheck=%2Fpreferences.php%3F
userupdate.php
May be missing missing closing bracket around Line 122? (On userupdate.php)
Parse error: syntax error, unexpected T_STRING, expecting ']' in /home/content/32/9092632/html/userupdate.php on line 122
Can you tell me where to eliminate the '&randomStringRegistration group' parts? I only want username and password to be forwarded to new users.
Getting this from the 'Please verify your email address', (Blank.php) email:
&randomStringRegistration group Email: joe@website.com
&randomStringRegistration group Password: userpassword
&randomStringRegistration group Confirm: userpassword
&randomStringRegistration group First Name: Joe
&randomStringRegistration group Last Name: Jones
&randomStringRegistration group Address: 222 main st
&randomStringRegistration group Address 2: 222 1st ave
&randomStringRegistration group City: margaritaville
&randomStringRegistration group State: fl
&randomStringRegistration group 10 Zip: 99208
&randomStringRegistration group 11 Country: United States
&randomStringRegistration group 1 Phone:
&randomStringRegistration group 1 Fax: 5555551212
&randomStringHidden Field:
&randomStringRegistration submit: Register
add the following code at line 1 of the login page:
<?php require_once( "webassist/security_assist/helper_php.php" ); ?>
the code near the end of line 122 has some hyphens that should not be there, see the attached screen shot.
in blank.php, change line 47:
<th style="font-size: 12px; width: 134px; text-align: right; padding: 3px 10px 3px 3px; font-weight: bold;">&amp;randomString<?php echo(str_replace("_"," ",$pkey)); ?>:</th>
<th style="font-size: 12px; width: 134px; text-align: right; padding: 3px 10px 3px 3px; font-weight: bold;"><?php echo(str_replace("_"," ",$pkey)); ?>:</th>
for details on removing some of the fields from the email message, see the "Customize the elements in your form-generated emails" tutorial on the data bridge support page:
data-bridge/
deanmale2001272549
Good until Login, then errors.
Hello Jason!
All (Registration, Email, Verify) worked good until I got to login.php, after successful verification.
Then the following errors after attempted Login:
Warning: Cannot modify header information - headers already sent by (output started at /home/content/32/9092632/html/login.php:3) in /home/content/32/9092632/html/login.php on line 33
Warning: Cannot modify header information - headers already sent by (output started at /home/content/32/9092632/html/login.php:3) in /home/content/32/9092632/html/login.php on line 38
Warning: Cannot modify header information - headers already sent by (output started at /home/content/32/9092632/html/login.php:3) in /home/content/32/9092632/html/login.php on line 53
Warning: Cannot modify header information - headers already sent by (output started at /home/content/32/9092632/html/login.php:3) in /home/content/32/9092632/html/login.php on line 58
Warning: Cannot modify header information - headers already sent by (output started at /home/content/32/9092632/html/login.php:3) in /home/content/32/9092632/html/webassist/security_assist/helper_php.php on line 56
make sure that there are no blank lines or spaces between php tags
the error is reporting the problem around line 3. most likely when you added the code i suggested at line 1, you left a blank space at the end. see this thread for details:
showthread.php?t=19285
deanmale2001272549
Thanks! All working.
Boy, I'm loving these lightning quick 6:00 a.m. in the morning replies!!!
Thanks again!
Weird about the space on header. Thanks for the tip. Learned something.
deanmale2001272549
Sorry Jason,
Maybe one more thing for now. I press the 'forgot password' link on login.php to re- send login credentials. Nothing sends and this error message comes on the forgotpassword.php page:
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/content/32/9092632/html/webassist/security_assist/helper_php.php on line 106
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/content/32/9092632/html/webassist/security_assist/helper_php.php on line 122
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/content/32/9092632/html/webassist/security_assist/helper_php.php on line 125
send a copy of the forgot password page please.
deanmale2001272549
forgotpassword.php attachment
(please see attached.)
edit the security assist email password behavior, and change it from using the locahost connection to use the remotehost connection.
deanmale2001272549
Would that be forgotpassword_email.php in the Security Assist Folder?
There is no localhost there.
(webassist/security_assist/) -folder hierarchy. Only thing I can come up with is an 'include' on Line 1, forgotpassword_email.php?
Example: <?php require_once( "webassist/security_assist/forgotpassword_email.php" ); ?>
