Powerstore Menu and Image Issues
Thread begun 2/26/2013 12:32 am by james366126 | Last modified 4/19/2013 10:03 am by Jason Byrnes | 1587 views | 3 replies |
james366126
How can I change the image in the home page store message pod? When I go to content and select the middle pod and edit it only allows me to change the header and the body text but has no options to change the image?
Also I'm having an issue with the menu. When I roll over a menu tab a sub category appears, when I go to roll over the sub menu it disappears. I think this is because there is a space between the menu tab and the sub category tab. How do I get rid of this space?
Thanks.
In the content management section, select the Home Page content, then edit the Site Message content area.
send a link where i can see the issue with the menu links to troubleshoot the cause.
Roz431315
I have the same issue with the sub menu...What what was the FIX?
you have another thread started that you report this issue in, please see the other thread.
