html5 framework builder
Thread begun 2/25/2013 3:43 am by CraigR | Last modified 2/25/2013 1:18 pm by Jason Byrnes | 4269 views | 9 replies |
CraigRBeta Tester
I tried setting my dreamweaver (CS6) prefernces so that new document is html5, but now when i try to create a new page with theme in framework builder, i get an error saying that there are regions in the document with no corresponding region in the new template. (document head).
Is there a way around this without manual editing ?
What doctype is the template that the theme is based on?
you should use the same doctype for the template and for the pages that use the theme.
CraigRBeta Tester
i started again, just to be sure
In dreamweaver preferences, i set new php document type to php 5
i then saved the document as a template,
i then opened framework builder, and tried to create page with theme, and got the error i outlined before
are you using the WebAssist -> Framework Builder -> Themes -> Create Page with Theme access point to create the page?
CraigRBeta Tester
yes, thats the route i take
Can you send a screen shot showing the error please, i am not able to reproduce.
CraigRBeta Tester
the zipped file is a basic page i created in dreamweaver and saved as a template.
template.jpg is a screenshot of the error.
template2.jpg is a screenshot of the javascript error which occurs if i subsequently click 'cancel'
Select the Document Head region, then in the Move to new region, select the head section.
CraigRBeta Tester
Thanks, that gets me a working page, but title tags and <meta charset="utf-8" /> are repeated on the resulting page unless i delete them afterwards
