Sessions for show if and allowing access
Thread begun 2/21/2013 7:07 pm by jo271221 | Last modified 2/22/2013 10:34 am by Jason Byrnes | 4880 views | 9 replies |
jo271221
I am having a great deal of trouble with show if rules and allowing access.
Our site has a log in page (attached), member directory, member posts and custom pages.
The member posts contain ads, news and events and I used datassist a few times to generate search and results pages. We also have a classified form which is joined with the posts.
The log in page shows session id which is what seems like I should be able to use the show if rule everywhere. Show is customerid matches the session of the user that is logged in.
The Auctions.php is working and using
if (isset($_SESSION['directoryid']) && $_SESSION['directoryid'] == $row_WADAevents['customerid']) {
I tried to use the webassist show utility tool on the Accomplishments-Updates.php page both with Session directoryid and id and neither works.
the code for the show if looks corrtect:
if ("".$row_pages['customerid']  ."" == "".$_SESSION['directoryid']  ."") {  // WebAssist Show If
so the question is what are the values of the $row_pages['customerid'] and $_SESSION['directoryid']
add the following code jsut before the show if code to output the values:
<?php echo("rs: ".$row_pages['customerid']."|| session: ".$_SESSION['directoryid'].""); ?>
this will help troubleshoot.
jo271221
show if
Here is the page: Accomplishments-Updates.php
Here is the output: rs: 6246|| session:
ok, so thats working. it's not showing the form because you are not logged in the recordset value does not equal the session
jo271221
Not logged in?
I am logged in - see attached screen shot. I am not sure if you are stating that everything is working I am just not logged in or you are trying to tell me something I am not understand.
Attached shows I am logged in as this user.
what do you get if you add a var dump of the session contents:
<?php car_dump($_SESSION); ?>
jo271221
array(15) { ["WAENCRYPTEDRETURNUSED"]=> bool(false) ["WAENCRYPTEDRETURNSUCCESS"]=> bool(false) ["EditReturn"]=> string(39) "/PrideFarms/Accomplishments-Updates.php" ["WADbSearch1_ads_horses_results"]=> string(0) "" ["WADbSearch1_custom_pages_results"]=> string(24) " AND (customerid = 6246)" ["theme"]=> string(13) "Barrel-Racing" ["SI"]=> string(2) "15" ["WAVT_postssearch_Errors"]=> string(0) "" ["WADbSearch1_posts_results"]=> string(22) " AND (interestid = 15)" ["directoryid"]=> string(4) "6246" ["email"]=> string(22) "greenforluck@yahoo.com" ["accesslevel"]=> NULL ["communityid"]=> string(1) "0" ["contact"]=> string(14) "Bryel Mulligan" ["membership_type"]=> string(26) "HotSite Hot Marketing Plus" }
ok, so according to this output the community ID session is 0:
which does not equal the value in the recordset:
rs: 6246
jo271221
show if / session issues
I added the vardump on this page to see if we can figure out why this page is working ads-events-news-featuredFW.php and the other pages are not.
It prints this: array(15) { ["WAENCRYPTEDRETURNUSED"]=> bool(false) ["WAENCRYPTEDRETURNSUCCESS"]=> bool(false) ["EditReturn"]=> string(21) "/PrideFarms/index.php" ["WADbSearch1_ads_horses_results"]=> string(23) " AND (customerid = 226)" ["WADbSearch1_custom_pages_results"]=> string(24) " AND (customerid = 6246)" ["theme"]=> string(10) "PrideFarms" ["SI"]=> string(2) "15" ["WAVT_postssearch_Errors"]=> string(0) "" ["WADbSearch1_posts_results"]=> string(22) " AND (interestid = 15)" ["directoryid"]=> string(4) "6246" ["email"]=> string(22) "greenforluck@yahoo.com" ["accesslevel"]=> NULL ["communityid"]=> string(1) "0" ["contact"]=> string(14) "Bryel Mulligan" ["membership_type"]=> string(26) "HotSite Hot Marketing Plus" }
Why does it show customerid=226 and customerid =6246?
What can we do to get the session for customer id to work ON EVERY PAGE?
