Data Bridge 1.1.3\Create Email Message
Thread begun 2/21/2013 8:05 am by michaelf0199272 | Last modified 2/21/2013 1:09 pm by michaelf0199272 | 3476 views | 5 replies |
michaelf0199272
After I applied Create Email Message to two pages on a customer's website. The pages simply stopped loading --- they are there on the hosting server.
i) when loaded it shows only blank page contact-us.php --- prior to applying Create Email Message to it --- it loadeded fine.
ii) Same as (i) solutions.php
The same file without "Create Email Massage" loads fine solutions2old.php
I don't get it --- all other files are loading fine. www.dotwem.com/
When I I tried to load the two pages in (i) and (ii) using google chrome, I get
"Server Error [HTTP Error 500]
The website encounterdedan error while retrieving contact-us.php. It may be down for maintenance or configured incorrectly." and it advised to reload the page later.
I get a similar HTTP 500 when I tried to load the pages on IE v 9
When I used IE v 6 --- it only showed blank
a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting
(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
michaelf0199272
Data Bridge 1.1.3/Create Email Message
Suggested codes have been added to both pages below.
i) contact-us.php
"Warning: require_once(../webassist/email/mail_php.php) [function.require-once]: failed to open stream: No such file or directory in /contact-us.php on line 5
Fatal error: require_once() [function.require]: Failed opening required '../webassist/email/mail_php.php' (include_path='.:/include:/usr/lib/php') in /contact-us.php on line 5"
ii) solutions.php
"Warning: require_once(../webassist/email/mail_php.php) [function.require-once]: failed to open stream: No such file or directory in /solutions.php on line 5
Fatal error: require_once() [function.require]: Failed opening required '../webassist/email/mail_php.php' (include_path='.:/include:/usr/lib/php') in /solutions.php on line 5"
the errors on the page are saying that the webassist/email/mail_php.php file has not been uploaded to the server.
upload the webassist folder to the server.
michaelf0199272
I think I fixed the problem.
michaelf0199272
Thanks Jason --- just reading your suggestion.
Yes --- I foundout that SmartFTPworks a bit differently.
