Related form, redirection question
Thread begun 2/21/2013 7:15 am by gdavis421484 | Last modified 2/21/2013 11:47 am by gdavis421484 | 3698 views | 6 replies |
gdavis421484
I have a main table (with a Main Form: tbl_mi_details_detail.php) and a related table with a related Form: (tbl_names_insert.php).
I have a slight problem with re-direction after an Insert Action in the Related Form.
The related Form has an action in the form tag of:
<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>
And an Insert Record 'After Insert' Server Behavior 'Go to' of:
tbl_mi_details_detail.php?RefNo=<?php echo ((isset($_POST["Insert_ID"]))?$_POST["Insert_ID"]:""); ?>
And a Cancel button:
<input type="button" value="Cancel" class="formButton" id="cancel" name="cancel" onclick="document.location.href='tbl_mi_details_detail.php?RefNo=<?php echo ((isset($_SESSION["Insert_ID"]))?$_SESSION["Insert_ID"]:""); ?>';" />
After inserting a new record I need to return to the Main Form with a url parameter and show the main record - as per the Cancel button above (the cancel button works correctly)
However, when I insert a record in the Related Form, the record is written to the related table but no re-direction back to the main form takes place i.e. the 'After Insert' Server Behavior does not seem to fire? (the trigger is 'Button: Current Page Submit')
I'm sure that I'm missing something simple here - any suggestions on how I get the GoTo working?.
so the cancel button is working fine using the Insert_ID session?
onclick="document.location.href='tbl_mi_details_de tail.php?RefNo=<?php echo ((isset($_SESSION["Insert_ID"]))?$_SESSION["Insert_ID"]:""); ?>';" />
in this code, your using a form element:
does that form element exist?
did you try setting the value of the Insert_ID form element to use the session variable?
<input type="hidden" name="Insert_ID" id="Insert_ID" value="<?php echo ((isset($_POST["Insert_ID"]))?$_POST["Insert_ID"]:""); ?>" />
gdavis421484
Hi Jason, thank you for the reply.
******* Yes that works OK
****** Yes Insert_ID is a hidden form element that uses the SESSION variable
****** Yes - also tried your suggestion below
I have attached the whole form.
gdavis421484
Hi Jason
I found this error message on the server:
[21-Feb-2013 18:49:08] PHP Warning: Cannot modify header information - headers already sent by (output started at /home/foresttr/public_html/MI/tblnames_insert.php:2) in /home/foresttr/public_html/MI/tblnames_insert.php on line 32
Putting <? ob_start(); ?> and <? ob_flush(); ?> at the begining and end of the page gets it working as required - but I'm not sure if this is the best solution?.
This does explain why the problem did not occur on my test (WAMP) server, it only started when I uploaded the files to my live server.
the headers already sent error is caused by output on the page between php tags.
the error is saying the problem is at line 2.
at line 1, you have the following code:
"<?php @session_start(); ?> "
i put in quotes to highlight the blank space at the end, that blank space after the closing PHP tag is the cause of the error.
gdavis421484
Thank You
Thanks Jason, you are right
I removed the space and the <? ob_start(); ?> and <? ob_flush(); ?>
Now it all works as expected.
Many thanks for your help - I'll remember to look out for extra spaces in future.
