Data bridge Contact and Thank pages problem
Thread begun 2/20/2013 11:31 pm by eladgraphics386618 | Last modified 2/23/2013 2:18 am by eladgraphics386618 | 2460 views | 4 replies |
eladgraphics386618
Hello
I have downloaded the latest data bridge. I have built the contact page and once I click the submit the preload of thankyou page come up but the thankyou page. It goes back to the contact page.
I have deleted the whole contact page, thankyou page and the webassist folder and start over for 3 times and same result.
Can you please help me? I don't know what I am doing wrong.
thanks
most likely it is failing vlaidation
to help troubleshoot, edit the following code on the thank you page:
if ($WAFV_Errors != "")  {
    PostResult($WAFV_Redirect,$WAFV_Errors,"thankyou");
die($WAFV_Errors);
this will help us see what validation is failing.
post back the result and fresh set of the pages, instead of converting the pages to text files, please leave them as php files.
eladgraphics386618
Thanks So much for quick reply.
I have changed the code and when test, I have the result ( ,5 )
I am attaching the contact and thank pages in dreamweaver
I have posted the site in www.culturenvacations.com
Again thanks so much.
in the validation code, 5 is the captcha validation.
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["Security_Code"])?$_POST["Security_Code"]:"")) . "",((isset($_SESSION["captcha_Security_Code"]))?strtolower($_SESSION["captcha_Security_Code"]):"") . "",true,5);
if you examine the code for the captcha image:
<img  src="webassist/captcha/wavt_captchasecurityimages.php?field=Security_Code_2&amp;bgcolor=FFFF99&amp;transparent=false&amp;noisefreq=50&amp;noisecolor=FFFFFF&amp;noiseorder=0&amp;gridfreq=25&amp;gridcolor=99FFFF&amp;gridorder=0&amp;font=fonts/MYTYPE.TTF&amp;characters=5&amp;textcolor=FF0000" alt="Security Code" class="Captcha" />
one of the URL variables is named field:
this is used to set the name of the captcha session variable as:
captcha_[Field Value]
or in the case:
captcha_Security_Code_2
the validaton, though, is set to use the session named:
this is why the validation is failing.
on the thank you page, change the captcha va;idation code:
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["Security_Code"])?$_POST["Security_Code"]:"")) . "",((isset($_SESSION["captcha_Security_Code_2"]))?strtolower($_SESSION["captcha_Security_Code_2"]):"") . "",true,5);
eladgraphics386618
Hello Jason
Thanks so much for the quick response.
I have tried and it worked perfectly.
I want to say big thanks for taking your precious time to point out the errors and show me how to fix it. Even though I know zero in php I could understand and have my work finish on time. You guys are great.
Thanks a million.
eladgraphics
