Dreamweaver Recordset not recognized
Thread begun 2/19/2013 2:08 pm by john70964 | Last modified 2/21/2013 12:37 pm by john70964 | 2797 views | 4 replies |
john70964
Not sure if I can be helped here as its is a very old site...
In Dreamweaver cs3 I am trying to ammend an old .asp site.
I tried to use an old version of data assist but could not get it to produce a result so I thought I would try the Dreamweaver method.
I need to create an Update a Record page.
I used Menu > Insert > Data Objects > Update Record > Record Update Form Wizard.
I create a Form, then go into the wizard and A box "Set up Instructions "
opens asking me to create a recordset.
I create a Recordset and use Test button which shows all records.
I click OK and the box Setup Instructions appears again still asking for a recordset.
The recordset code does appear in the page.
I have to cancel the Setup Instructions box to proceed.
If I then try to create the update Form the recordset the Setup Instruction Box reappears the existing recordset is not recognised.
This can be seen in the attached image and code.
I quite understand if this too old to get answered
John
if you test the recordset, does it return a result?
if you go to the bindings panel does it show a binding group for the recordset?
sounds like a problem with the site definition settings.
if the recordset doesn't display in the bindings panel, double check the site definition settings.
john70964
Thanks for your reponse Jason
Yes
Yes
I tried creating a non wizard Update via
Server behaviours > Update Record but still came up with Please create recordset
The recordset is created.
Image shows.
Any ideas welcomed!
john70964
I must thank Jason for helping me on this problem.
Jason quickly identified my problem as being the use of reserved access words perhaps 2 or even more!
Jason carefully explained how important it is to have a method whereby reserved words cannot be used.
This is best carried out by applying tbl before the table name so a table could be called tlbproducts
If the table name is tlbproducts
The field names would perhaps be
productsID
productsName
productsDescription
As Description is a reserved word in access productsDescription would not present a problem.
I write this down as a reminder to me for the future and if it helps anyone that's great also.
Many thanks again Jason and I trust I have this all correct!
Regards
John
