Can't Change UPS Shipping Setting
Thread begun 2/19/2013 7:12 am by lee365928 | Last modified 2/20/2013 6:43 am by Jason Byrnes | 3081 views | 7 replies |
lee365928
This has been set up for a long time, but now it won't let me change the "3" value in the attached screencap. I've tried the basics, restarting, deleting the MacFileCache file and trying to make the change using both CS4 and CS5. The same thing happens. It will let me change the value. Then I will click ok and close the window. If you open the same file again, the value is still 3. Any ideas?
do you have the option to checkin and checkout files on your site enabled?
if so, make sure to checkout the eCart object file before trying to make changes.
lee365928
No. That option isn't enabled on the site.
is the eCart file set to read only access? If the eCart files are read only, updates wont be able to stick.
lee365928
Everything in the WA_eCart folder is set to the following;
admin (Me) - Read & Write
Everyone - Read Only
what are the permissions on other files of the site that can be updated?
do the eCart files permissions match?
lee365928
The permissions on the other files are the same.
