Double Opt In Registration System emailVerifted ?
Thread begun 2/14/2013 6:09 am by john411474 | Last modified 8/12/2013 8:33 am by Jason Byrnes | 2172 views | 4 replies |
john411474
Working thru your Double Opt in Registration instructions
Building page user-comfirm.php
"Reset the user's session variable to verified status"
Changed trigger to Recordset:reVerify is not empty
I have no option emailVerified for the name
jrt
you will need to create the binding then.
open the bindings panel, click the plus button and select Session, set the name to emailVerified
kevin_d_allen182238
Glad to find this posted... Just spent 3 hours going back & forth through the pages I've created and the Video Tutorial.... trying to find the step I'd skipped.
kevin_d_allen182238
rsVerify vs. reVerify Video Tutorial differs from written Tutorial
I noticed that the written tutorial calls this variable "reVerify" in this step of the process - whereas the VIDEO Tutorial calls it "rsVerify" - are there any other differences between the two tutorials?
I will forward this along to the documentation team.
I'm not aware of other differences between the video tutorial and the written tutorial. in reality, the name of the recordset is not that important as long as you you use the same name consistently in your application.
