redirect page and form function problems
Thread begun 2/13/2013 8:23 am by roby258376 | Last modified 2/13/2013 10:17 am by roby258376 | 5073 views | 11 replies |
roby258376
Hi there,
I have created a new form but every time I go in to change anything, the form function (ie send emails to etc., has been reset to empty. so my first question is, how do I get it to stop making me enter that information every time? (this info does not appear to be being saved at all as when I test the form, no emails are sent)
Secondly, I need to redirect the form to a thank you page but that area is greyed out. Where do I change it?
you can only set the form functions when you create the form, not when you edit the form.
the form functions are saved in the Universal Email server behavior.
if you need to edit them, open the server behaviors panel, and double click the universal email server behavior. This is also where you can set the redirect.
roby258376
Something isn't working correctly then because I have no Universal Email listed under Server Behaviours even though I have put it in about a dozen times so far...
send a copy of the page please.
roby258376
Additional info: After installing CSS form builder I am now getting this error when I launch DW
The following JavaScript error(s) occurred:
At line 383 of file "C\Users\Robin Dell\AppData\Roaming\Adobe\Dreamweaver CS6\en_US\Configuration\shared\WebAssist\FormBuilder\Library\WA_Configuration.js":
toCheck has no properties
The Stand Alone version of css form builder is not compatible with DW CS6, it has been replaced by Data Bridge.
to use form builder in DW CS6, you will need to upgrade to Data Bridge.
roby258376
a .zip of the page is attached. Please let me know if that's not what you wanted
roby258376
upgrade for $149? when I've already paid for most of what's included? as well as paid for an earlier version of Super Suite? Who do I contact to see if anything can be done about that?
$149 is the cheapest upgrade to Data Bridge that we offer.
the upgrade includes a newer version of Data Assist than the version you would already have in addition to offering CS6 support.
roby258376
ok, I've purchased and installed Data Bridge.
I recreated the page, inserting a new form and using the preset I made earlier.
I then edited the information in the Form Functions area and clicked Finish
the form works as intended, redirected me to the right page and sent out the email as expected.
However, I still do not have an EMAIL server behaviour so I am still not able to edit the email.
Robin
