databridge
Thread begun 2/12/2013 9:57 am by info350379 | Last modified 2/13/2013 7:08 am by Jason Byrnes | 2673 views | 5 replies |
info350379
databridge
Dear sir/ madam,
Have a problem with databridge 1.1.3, formbuilder.
I use 2 form elements on one website but now the second one is overwriting the first one because of the same names. (spryassets en webassist) I've tried a lot of things already but I can not figure it out what I must do.
Hopefully you can help me out to find the good direction.
With Regards,
Aart
I dont follow, can you pl,ease give more details, also a copy of the pages would be helpful.
info350379
data bridge
Hi Jason.
What I mean is, I created 2 different forms on one website.
When I generate the first form with formbuilder, everything works fine. But when I create the second one, he generate the same folderfiles. so he overwrite the first one, because it use the same foldernames.
The forms are on two different pages!
the foldernames the formbuilder generates after making the form are (spryassets en webassist)
regards,
Aart
yes the spry assets and web assist folders will be created by each form, but the files in those folders are generic files and not specific to the form.
info350379
databridge
Hi Jason,
Thank you for your answer.
What you are saying is that those files do not change after creating the second form?
Is this correct?
So each file(webpage) with the formelements I can change without that it will affect the other page.
I will make 2 new pages with formelements in dreamweaver and will let you know what happend.
Maybe I did something wrong there.
With kindest regards,
Aart
Yes, that is correct.
