Universal Email Header problem 2
Thread begun 2/12/2013 9:12 am by john70964 | Last modified 2/14/2013 1:55 pm by Jason Byrnes | 4921 views | 14 replies |
john70964
Hello
I have an insert page which sends a Universal Email message.
This works correctly on my Local Machine but when I load it to the server to use I get the following messages at the top of the page.
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/username/boat-for-sale.co.uk/Enquiries/boatenquiry_insert.php:22) in /home/username/boat-for-sale.co.uk/webassist/email/mail_php.php on line 274
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/username/boat-for-sale.co.uk/Enquiries/boatenquiry_insert.php:22) in /home/username/boat-for-sale.co.uk/webassist/email/mail_php.php on line 274
Warning: Cannot modify header information - headers already sent by (output started at /home/username/boat-for-sale.co.uk/Enquiries/boatenquiry_insert.php:22) in /home/username/boat-for-sale.co.uk/Enquiries/boatenquiry_insert.php on line 187
I checked the positioning of the Universal Email and it is above the DocType tag.
I am attaching a copy of the file in the hope the problem can be identified.
Many thanks
John
there is a blank line between php tags at line 21.
line 19 - 22:
<?php require_once("../webassist/database_management/wa_appbuilder_php.php"); ?>
should be:
john70964
Thanks Jason,
I took that blank line out but now the page boatenquiry_insert is ignored and the thankyou page opens immediately.
john70964
In the form action on the preceeding page I changed the post to GET
<form action="Enquiries/boatenquiry_insert.php?RecNo=<?php echo $row_DetailRS1['RecNo']; ?>" method="get" enctype="multipart/form-data">
and now the insert page shows but the two validation ifs do not allow the page to go forward.
The boxes are completed, name and email but when the insert button is pressed the warning text shows.
In first box is alpha numeric the second box is email.
change the method back to post.
change the trigger for the universal email behavior to use the submit button.
john70964
Thanks Jason nearly there!
With those last changes the insert page opens correctly but it seems the validation show ifs will not allow the page to submit. The database table is not updated.
I am attaching the latest insert file
in the server validation, the bindings you are using for the server variables are the bindings from the Validated entries collection, not the bindings from the form elements.
the validated entries collection is only populated if validation fails and cannot be used for the validation.
john70964
Thanks for all the help Jason,
In boatenquiry_insert.php I cannot seem to get the correct recordID number showing in the
Boat Record No: Box
I am testing with RecNo 9474 but when opened the page pulls in 8512 which is the first record in the table boats.
I cannot see why Recordset DetailRS1 does not select the correct record but only the first record.
I have used RecNo, recordID and colname all give the same results. 8512
I am attaching the latest ammended file. and an image which I think shows the problem.
the recordset code is duplicated. lines 53 - 65
$colname_DetailRS1 = "-1";
if (isset($_GET['recordID'])) {
  $colname_DetailRS1 = $_GET['recordID'];
mysql_select_db($database_conn1, $conn1);
$query_DetailRS1 = sprintf("SELECT * FROM boats WHERE RecNo = %s", GetSQLValueString($colname_DetailRS1, "int"));
$DetailRS1 = mysql_query($query_DetailRS1, $conn1) or die(mysql_error());
$row_DetailRS1 = mysql_fetch_assoc($DetailRS1);
$totalRows_DetailRS1 = mysql_num_rows($DetailRS1);
$query_DetailRS1 = "SELECT * FROM boats WHERE RecNo = RecNo";
$totalRows_DetailRS1 = mysql_num_rows($DetailRS1); ?>
should be:
if (isset($_GET['RecNo'])) {
  $colname_DetailRS1 = $_GET['RecNo'];
john70964
Thanks Jason
I removed the excess code and now it works on my local machine.
I cannot see the recordset now in the bindings or the SB's. Is there a way of getting that back?
I uploaded the file to the server to the server and when I try to insert the information on boatenquiry_insert.php
I get an error message Duplicate entry '0' for key 'PRIMARY'
