on state
Thread begun 2/12/2013 8:43 am by JamieEff | Last modified 2/13/2013 8:33 am by JamieEff | 1744 views | 2 replies |
JamieEff
on state
Hey Jason
Not sure what I have done wrong here.
If you go to bridal.php you will see that the side navigation highlights the page you are on (in this case 'Bridal') but if you go to any of the top navigation none of them have the on state (which is the same as the hover state)
Jamie
the top menu is not set to highlight the current item.
change the following code:
<script type="text/javascript">if(window.attachEvent) { window.attachEvent("onload", function() { topNav.intializeMenu('topNav',{select_current: 0, orientation: 1}); }); } else if(window.addEventListener) { window.addEventListener("load", function() { topNav.intializeMenu('topNav',{select_current: 0, orientation: 1}); }, true); }</script>
<script type="text/javascript">if(window.attachEvent) { window.attachEvent("onload", function() { topNav.intializeMenu('topNav',{select_current: 1, orientation: 1}); }); } else if(window.addEventListener) { window.addEventListener("load", function() { topNav.intializeMenu('topNav',{select_current: 1, orientation: 1}); }, true); }</script>
JamieEff
I was sure that I had set 'Current' to 'Current page only' - I guess not :( sorry about that Jamie
