Slug from Title
Thread begun 2/12/2013 3:32 am by Daryl | Last modified 2/12/2013 6:16 am by Dave Buchholz | 1220 views | 2 replies |
DarylBeta Tester
Slug from Title
I have been for years trying to get my head round mod_rewrite and Pretty URLs, and the recent email and Davids example has given me the bug.
I am trying to get my head round 'slugs'. I understand the concept and why we need them, but am trying to figure out how to get DataBridge to do this for me.
I have a Title, Introduction and Content field in a form (as well as date, user etc), and then want the Databridge form to send a slug to the slug column which would be a title with hyphens instead of spaces and special characters removed. I assume that this is generated by the title form field but am not sure how I a) alter the title and b) how I get the form to insert the title in to the title column and the modified version into slug as it will be coming from the same form field.
I have been reading this link which gives me the function;
function create_slug($string){
   $string = preg_replace( '/[«»""!?,.!@£$%^&*{};:()]+/', '', $string);
   $string = str_replace( "'", '', $string);
   $string = strtolower($string);
   $slug=preg_replace('/[^A-Za-z0-9-]+/', '-', $string);
   return $slug;
$slug = create_slug($title);
But Im not sure where to put this and how to integrate it into an insert form.
Thanks in advance
DarylBeta Tester
OK....
I have figured out how to submit one form field to two different columns;
Open the insert record behaviour and then choose the dynamic value as the same form field.
<?php echo ((isset($_POST["title"]))?$_POST["title"]:""); ?>
Then to remove special characters, make lowercase and replace spaces with hyphens, I changed the lightening bolt value to look like the following
<?php echo (preg_replace('/[^A-Za-z0-9-]+/', '-', str_replace( "'", '', preg_replace( '/[«»""!?,.!@£$%^&*{};:()]+/', '', strtolower((isset($_POST['title']))?$_POST['title']:""))))); ?>
I'm not sure if this is the most efficient way, and I'm willing to be told, but it works!
Dave BuchholzBeta Tester
Daryl,
I store the slugs in their own field in the db table and wrap the insert field with a function like so:
"|" . "".((isset($_POST["slug"]))?i8_UrlParameter($_POST["slug"]):"")  ."" . "|"
