DataAssist passing values
Thread begun 2/10/2013 2:10 pm by john70964 | Last modified 2/11/2013 1:29 pm by Jason Byrnes | 3393 views | 6 replies |
john70964
I have a detail page which shows a recordNumber and details.
I want to pass the RecordNumber and some details to a Next page which will insert those details into another db Table.
Can anyone say how this can be carried out please?
Many thanks
John
john70964
I took this a little further and by going to webassist > cookies >set session value created the value
@session_start();
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$_SESSION["BoatResultsSession"] = "".$row_DetailRS1['RecNo'] ."";
I then included this session in the recordset of the insert page. The insert page opens but the url does not contain a RecNo (recordID) and the text field recno remains empty.
I am attaching the detail and the insert page in the hope for some guidance.
Many thanks
John
you have bind the initial value of the form elements to the corresponding columns from the recordset.
for each form element, click the lightning bolt icon next to initial value in the properties inspector, and select the corresponding column from the recordset on your page.
john70964
On the insert page I have placed one text field recNo where its initial value is bound to the corresponding field in the recordset, (as a test field).
I notice the results url is /BoatResultsDetail.php?recordID=9474
but the insert page url is /Enquiries/boatenquiry_insert.php but excludes reference to the recordID
Does this have a significance?
John
you have not set the detail page to pass the ID as a querystring, nor do i see anywhere on the insert page where the query string is being used.
john70964
Thanks Jason
I am now passing the ID as a query string and am getting the recordID showing in the insertpage as Enquiries/boatenquiry_insert.php?RecNo=9474
In the insert page I am trying to insert fields (pull in) from the details page so that the field
SellerRecNo is now set to <?php echo $row_DetailRS1['RecNo']; ?> and my thinking is that it should show 9474 like wise other fields should show fields from the details page.
However the fields remain empty.
I am attaching an updated insert page, can see what may be incorrect please?
1) The recordset is set to filter on the $_SESSION['BoatResultsSession'] variable, not the RecNO URL Variable.
2) The form elements are getting there values from the validated entries collection, not from the recordset.
