datepicker issues
Thread begun 2/08/2013 5:55 am by JamieEff | Last modified 6/14/2013 11:08 am by Jason Byrnes | 5434 views | 11 replies |
JamieEff
datepicker issues
Hey Jason
Have added a datepicker to e _results and an _insert page and both of them are showing " Invalid format.Please enter a value." next to the datepicker field.
Also, although I have set the datepicker to use the UK format (ie dd/mm/yyyy) the results page shows in the US format and is getting the months muddled with the days and so on....
TIA
Jamie
please include a copy of the pages.
JamieEff
here you go Jason
on the insert page, change the following code:
var BlogDate_Spry = new Spry.Widget.ValidationTextField("BlogDate_Spry", "date", {isRequired: false, format:'mm/dd/yyyy', validateOn:["blur"]});
var BlogDate_Spry = new Spry.Widget.ValidationTextField("BlogDate_Spry", "date", {isRequired: false, format:'dd/mm/yyyy', validateOn:["blur"]});
on the updatepage, change the following code:
and this code:
<input id="BlogDate" name="BlogDate" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("blogupdate","BlogDate"):"".(($row_WADAblog["BlogDate"])?date("n/d/Y",strtotime($row_WADAblog["BlogDate"])):"")."")); ?>" class="formTextfield_Medium" tabindex="2" onBlur="hideServerError('BlogDate_ServerError');">
<input id="BlogDate" name="BlogDate" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("blogupdate","BlogDate"):"".(($row_WADAblog["BlogDate"])?date("m/d/Y",strtotime($row_WADAblog["BlogDate"])):"")."")); ?>" class="formTextfield_Medium" tabindex="2" onBlur="hideServerError('BlogDate_ServerError');">
JamieEff
thats not changed whats happening I'm afraid... on the insert or update page, the 'error' Invalid format.Please enter a value. is showing regardless of whether or not there is any content in the field. Also, on the results page, if I have entered 15 Nov 2010 on an insert or update page, the date showing in the results page is: 30 Nov -0001 (and then subsequently showing that in the update page)
this_is_me
similar issue
I have two datepicker events on the insert page - a start and a stop field.
The start field populates the database correctly: 2013-11-06 00:00:00, but the stop field shows: 1970-01-01 01:00:00
this_is_me
thank you Jason
I am on a development server, because the public webspace is not online yet. Where do have to look. I can live with the fact that the code is buggy insofar as the Spry validation field does not switsch to the new date format. I have don this manually.
Originally Said By: this_is_me
