File Download not working
Thread begun 2/07/2013 4:38 pm by jebrandon343719 | Last modified 2/14/2013 1:18 pm by Jason Byrnes | 3340 views | 5 replies |
jebrandon343719
I have inserted a server behavior for a file down load. Everything looks fine. When the page loads, nothing happens???
I have done this so may times before?? What would be stopping the file from downloading ???
either the trigger trigger for the download is not occuring, or the download file does not exist at the path you specified.
send a copy of your page please so i can see the code.
jebrandon343719
The file is uploaded CapitalHHealth.pdf
code attached. Thanks
2 problems i can see.
1) the download code:
WA_DFP_SetupDownloadStatusStruct
("WA_DownloadResult1");
if(isset(
$_POST["Download"])){
WA_DFP_DownloadFile("WA_DownloadResult1", "digital/", "Capital H Health.pdf", "[FileName]", false, false, false, "", "", "", "");
is set to use a form element named "Download" for the trigger. This would be fine if your submit button where a standard button, but you have used an image element type so:
if(isset($_POST["Download"])){
should be:
if(isset($_POST["Download_x"])){
2) In the download code, the file name is:
but your link does not contain spaces, it should be:
"CapitalHHealth.pdf"
jebrandon343719
Still not working
This still doesn't work. I have tried changing to normal button etc...
I have been getting this error message when opening pages (other sites as well), maybe its a clue - see attached
