Css menu drop down issue
Thread begun 2/07/2013 8:37 am by chall381853 | Last modified 2/20/2013 12:37 pm by Jason Byrnes | 4797 views | 9 replies |
chall381853
I created a menu using Css Menu writer and I added a drop down with links. When I try to click on the drop down when previewing it instantly disapears when the mouse hovers over the drop down.
Normally, this happens when viewing the menu in IE if you don't use a pixel measurement for the width of the menu items.
In the menu settings, make sure to specify a width for the top level and sub-level menu items using a pixel measurement, IE will not work correctly if the width is left blank, or set to auto.
if you continue to have a problem, i'll need a link where i can see your menu.
chall381853
Here is what Im working with.
I don't understand why the menu drops down but disappears immediately. I'm previewing it in chrome and Firefox as well, however, it still does the same thing.
I Will need a link to see the problem in order to troubleshoot.
chall381853
I cant send a link
The site is not hosted or online. Im simply working in dreamweaver for right now.
It's impossible to troubleshoot a problem like this without being able to see it in a browser. I would need to see the menu in a browser to be able to troubleshoot design problems like this.
chall381853
Is there anyway I could get help with this?
Thank you. We can screen share or something.
screen sharing is really a terrible way to troubleshoot this sort of issue, it is much better to troubleshoot directly in the browser.
marsha431457
CSS menu dropdown issue
Did this issue ever get solved? I have the same problem in ALL browsers (Firefox & Safari, haven't tested in IE yet).
send a link where i can see the problem to investigate the cause.
